'76 Salon Cruise Control Problem . . .
Old Aug 13, 2025 | 12:43 PM
76CutlassSalon's Avatar
Big Red, our '76 Salon's cruise control vacuum bellows has given up the ghost. I have tried to search for a good one online, but I do not have a known-correct part number. The car has an Olds 350, A/T and A/C if that makes a difference.
Does anyone know the correct part number? And does anyone have a known good one for sale? Failing that, does anyone rebuild these units?
Thanks,
Jeff
Old Aug 13, 2025 | 01:23 PM
Did you check with Fusick?
https://www.fusickautomotiveproducts.com/
Old Aug 13, 2025 | 05:37 PM
Bill G's Avatar
Not sure if this helps but I took a pic from my '76 parts book related to CD. Would the 'bellows' have another name?
Only thing showing in illustrated book is regulator..
sorry for poor pic..
Old Aug 14, 2025 | 05:20 AM
jaunty75's Avatar
Fusick would never stock something like this because the potential market is far too small. If you search "cruise control" at their site, you find wiring harnesses and speedometer cables and that's about it. Plus, Fusick doesn't have much for cars after 1972 and almost nothing at all for post-1975 cars.
It's almost a certainty these vacuum diaphragms are not made new today. One route is to try to find a junkyard car with a working diaphragm.
Another possibility is that this same part was used in other GM makes around that time. If this same part was used in a Chevy Malibu, say, you might have an easier time finding one. If you can find out what the part number is and then get hold of a parts interchange manual, you might be able to find other cars that used this same part. If it was also used in a Chevy, it might be made new by a Chevy supplier.
I think it's going to take some time and effort to track one down.
Old Aug 14, 2025 | 11:32 AM
Okay, I found the GM number for the servo: 1498988. It looks like this, but I will consider something close if it seems adaptable.NOS 1970s Oldsmobile OLDS CRUISE control vacuum SERVO new in original GM box! - Image 1 of 3
Last edited by 76CutlassSalon; Aug 14, 2025 at 11:36 AM. Reason: Additional info provided in listing.
Old Aug 15, 2025 | 04:32 AM
jaunty75's Avatar
That photo is from an ebay listing. They're asking $375 for it. That's steep, for sure, but if you need one, you need one.
https://ebay.us/m/lvRVJR
Old Aug 15, 2025 | 04:42 AM
Bill G's Avatar
If you’re looking for a servo my 76 parts book shows 551095
the other number comes up online as a tee.
Old Aug 15, 2025 | 05:03 AM
I had considered posting the link to Kanter but thought the chances of finding one at Fusick would be better.
Now that we have the part number, is that the same vacuum diaphragm used by older Cutlii?
When I had my 96 98 it developed an intermittent cruise condition. I never cured it before I scrapped the car but I did disassemble the vacuum cruise actuator and clean the rubber parts with belt dressing. While this didn't completely cure the problem it did mitigate the cruise from falling out for a time.
Old Aug 15, 2025 | 07:35 AM
Thanks!
jasesquire
Ninety-Eight
Nov 7, 2025 05:59 PM
1BOSS83
Mar 24, 2016 04:56 PM
WendellB
Apr 29, 2015 02:55 PM
86Aero
Jan 25, 2015 11:16 AM
87cutlasssupreme
Apr 27, 2009 04:20 PM
