75 delta 88 convertible - radio install question
Old Jul 30, 2017 | 05:53 PM
jja18's Avatar
Hello,
I have a 75 delta 88 convertible. When i purchased it, the radio was replaced with an old 2 **** radio (but they gave me the original - not sure if it works).
I purchased a kenwood 2 **** radio as a replacement (with RCA output, because I want to add amps), but then I changed my mind because most of the music I listen to is off my phone or streaming.
I plan to purchase a regular din radio, but have reservations about cutting my dash. Has anybody done this? I understand the wood panel removes, and there is another piece behind it that would need to be cut as well (and runs the whole length of the dash, if I want to take out to replace)
my options as I see it:
1. buy replacement dash, cut that one and put my radio in - save the original dash and radio if I sell the car (if the new owner wanted it). This just seems like a lot of work....
2. put original radio back in the dash (for looks), and put new radio in an under dash kit or glove box.
3. use the 2 **** kenwood that I bought but lose streaming ability (least preferred option)
Am I being too crazy about cutting the dash? the car is almost 100% original, but certainly not a show car/trailer queen, but maybe 1 day if I sell it, it will make a difference to somebody if the dash has been cut. I'm sure a time will come where parts are not so readily available..
Those modern 2 **** replacements with bluetooth/RCA's that are sold have horrible reviews, so I don't want to go that route.
Any opinions?
Old Jul 31, 2017 | 03:29 AM
Fullsizelover's Avatar
You got try option 4: get the original radio rebuild to new specs how you want it. I bought a Retrosound myself but I mostly use USB, however the option to scroll through the folders already doesn't work anymore and the radio is crappy..
Old Jul 31, 2017 | 09:36 AM
Don't cut the dash on your car to install a radio. Here's how I installed a DIN radio in my 71 98:
https://classicoldsmobile.com/forums...y-71-98-a.html
Plus, there are other threads with some good info on various radio options. Check it out!
mefirst72
Mar 29, 2016 05:47 AM
psnieds1
Oct 27, 2013 08:10 AM
Texas69
Feb 11, 2012 05:21 AM
ent72olds
Jul 10, 2009 08:53 PM
tbirdr
Oct 30, 2008 05:22 PM
