Radio install - constant power lead
Old Feb 10, 2012 | 02:59 PM
Texas69's Avatar
Hi -
I am looking at replacing my existing aftermarket radio with another in my 69 Cutlass. I will use the yellow factory radio lead for the switched power. My dash clock is not in use and am considering using the orange clock power lead as a constant 12v source for the radio's memory etc.
I assume this is indeed a constant power source, or else the clock would be wrong all the time, right? Any other considerations? Just looking for a quick easy solution without tapping into wires or the fusebox.
Ray
Old Feb 10, 2012 | 08:42 PM
rcorrigan5's Avatar
Randy C.
If it's anything like my '68 or '69, orange is hot all the time (check the lead to your lighter - it should also be orange and hot all the time) and yellow is the hot to your radio (hot when car is started or in acc position).
Randy C.
Old Feb 10, 2012 | 08:54 PM
Lady72nRob71's Avatar
Yes, the orange clock feed is constant 12V. If it was switched, the clock would be just an hour meter for runtime...
Shoudl you want to use the clock again, the same lead can be used for both since the current draw is so low.
Old Feb 11, 2012 | 05:21 AM
jaunty75's Avatar
You can check this faster than the time it took you to sit down at your computer and post the question on here. With a voltmeter or test light and the ignition off and the key out, see if there's 12 volts on it.
As noted, the clock lead most certainly needs to be a constant 12 volts or the clock would run only when the ignition is on, and what good would that be?
Alex72cutty
May 20, 2015 11:07 PM
delta_88_germany
Feb 22, 2014 01:48 PM
Clydesdale
Aug 2, 2012 07:24 AM
senginc
Drivetrain/Differentials
Jan 2, 2012 08:52 AM
jerseyjoe
Suspension & Handling
Dec 27, 2010 12:54 PM
