1965 Gauge Cluster PIN descriptions
Old Jan 1, 2024 | 02:40 PM
65jeff442's Avatar
Hi all,
Been re-assembling the dash after getting the car back from paint and restoration. I'm tracking down an issue with the fuel gauge and have reviewed a number of the threads on this site on troubleshooting issues including this one: https://classicoldsmobile.com/forums...utlass-175028/.
I had someone else do the re-wiring of the dash using a Painless wiring kit since under the dash was a total mess of cutoff wires when I started disassembly for the paint. I'm trying to find out if part of my issue may be the way that the gauge cluster wiring was done when he set the new wires in the slots. I have the Body Service Manual and the 1965 Cutlass Assembly manual and can't find a diagram of what each of the pins is for. I looked at pages: 12.3.11; 12-3.12. Is there somewhere this is available?
I've attached a pic of the back of the gauges from my dash and will go back to troubleshoot the fuel gauge once i get that.
I appreciate any help you guys can provide.
Old Jan 2, 2024 | 12:42 AM
It's actually pretty easy to just follow the traces on the flex-print wiring and match them up to the diagram in the PIM.
Old Jan 2, 2024 | 03:31 AM
Joe - Hole Smokes. I'm assuming you put that image together? That's fantastic! Nice job.
Old Jan 2, 2024 | 06:21 AM
Can you tell that I make a lot of Powerpoint slides for my day job?
Old Jan 2, 2024 | 07:13 AM
Indeed. When I was a paid working man I did same. At some point I believe I may have downloaded every PP template known to mankind.
Old Jan 2, 2024 | 08:16 AM
65jeff442's Avatar
You guys are awesome! Joe, thanks for that quick turnaround and a great diagram.
Old Jan 2, 2024 | 08:33 AM
I did squat....
Tiberian Fiend
Aug 7, 2018 12:01 PM
neatolds
Aug 17, 2015 02:35 PM
hueveaj
Feb 23, 2014 06:53 PM
Black1984SNAPPING
May 14, 2013 09:23 AM
rum1
Jul 20, 2010 07:22 AM
