#194 dash lights
Old July 19th, 2018, 03:12 PM
abrasv's Avatar
#194 dash lights
My dash lights in my 69 Cutlass are very dim or I'm older then I pretend. Installed a new head light switch and rheostat works fine but even when it is the brightest still hard to see.
Has anyone replaced the standard 194 bulbs with anything brighter?
abrasv is offline
Old July 19th, 2018, 03:43 PM
My442's Avatar
168 bulbs are brighter.
My442 is offline
Old July 19th, 2018, 06:46 PM
Have you checked your battery voltage and alternator? When did you first notice the problem? It could also be a weak ground somewhere in your lighting circuit.
Allan R is offline
Old July 19th, 2018, 07:21 PM
oldspackrat's Avatar
LED bulbs really brighten things up. They are inexpensive on ebay. I offer them on my gauge restorations. If you do get them be aware they are not dimable, at least not with the factory headlight switch, & they will only work one way in the socket. If they don't work, turn the socket 180 degrees & reinstall.
oldspackrat is offline
Old July 19th, 2018, 07:33 PM
Brighter incandescent bulbs are also hotter. Using a higher wattage than the 194 bulb can overheat the instrument panel and potentially melt plastic parts. LEDs avoid that problem.
joe_padavano is offline
Old July 20th, 2018, 06:24 AM
The old lights can be as bright as they were new, but certain things can affect it, like any resistance in the circuits.
Koda is online now
Old July 20th, 2018, 08:46 AM
My442's Avatar
https://www.sylvania-automotive.com/apps/vlrg-us/Vlrg/
My442 is offline
My2nd 69 442
January 19th, 2018 04:49 PM
Christophe2m6
October 31st, 2014 11:37 AM
bcg88
April 28th, 2012 11:02 AM
Firstcutlass
September 16th, 2011 05:26 PM
Fletch
October 6th, 2009 06:16 AM
Quick Reply: #194 dash lights
