Tic Toc Tach wiring...
Old July 20th, 2018, 12:42 PM
71OldsCut's Avatar
Hi guys, does anyone have experience with the aftermarket wiring for the tic toc tach? I am just confused about how the end fits together. I see that the plastic parts slip in together and twist to lock, but unless there is tension on the spring in the large white plastic piece, what keeps it locked together and the contacts connected? I have some pics below.
Thanks,
71OldsCut is offline
Old July 20th, 2018, 12:45 PM
BackInTheGame's Avatar
A fuse goes into the cavity before connecting the two twist-lock pieces.
BackInTheGame is offline
Old July 20th, 2018, 12:47 PM
71OldsCut's Avatar
That makes sense, lol. Do you know what amp? Hopefully I can still find that style somewhere. I haven't had to use them in a long time
Old July 20th, 2018, 01:00 PM
Texas69's Avatar
Tach fuse
FWIW, the aftermarket tach fuse wiring I got from Parts Place required some modification so that the fuse would actually fit the fuse holder. I think I ended up shortening the spring in the fuse holder by snipping a few coils.
For 1969, the CSM specifies a 2 amp fuse. Not sure if it is applicable to your year car. Note that the fuse provided by the Parts Place with the tach wiring was 0.5Amp and not correct.
Texas69 is offline
Old July 20th, 2018, 05:53 PM
71OldsCut's Avatar
Thanks guys, with a bit more research I went with a 2 amp fuse. I too had to cut some coils out of the spring to make it fit. It is in, and both the clock and the tach work. It looks great. Now, on with the carb install...
JOHNNYOLDS442
March 9th, 2018 05:51 AM
bwayco
April 15th, 2017 09:37 AM
My2nd 69 442
September 22nd, 2016 03:32 PM
rr69ho
February 1st, 2015 03:26 AM
costpenn
May 3rd, 2012 04:21 AM
Quick Reply: Tic Toc Tach wiring...
