Glue for my hood liner or no?
Old Apr 5, 2013 | 06:47 PM
navvet's Avatar
Replacing my hood liner AGAIN ( last one began to tear cheap quality)
What type if any glue should I use to hold the pad onto the hood along with the metal clips?
Old Apr 5, 2013 | 07:30 PM
Al Graaf's Avatar
Formerly "Shimmer"
I would suggest contact glue-be sure to wait as they say before you place it
Good luck!
AL
Old Apr 5, 2013 | 08:10 PM
jaunty75's Avatar
I just replaced the hood pad on my '67 Delta. In addition to the plastic clips, I used 3M weatherstrip adhesive to hold it on in the various places where the previous one was glued. Stuff works great.
Old Apr 6, 2013 | 11:14 AM
Al Graaf's Avatar
Formerly "Shimmer"
Good choice I forgot about that stuff!
Old Apr 6, 2013 | 02:33 PM
Tedd Thompson's Avatar
I have used 3M #90 spray adhesive and it worked fine and was easy to apply, make sure its #90 and not the more common #77 which doesn't have as much tac.....Tedd
Old Apr 6, 2013 | 03:17 PM
I've also used the 3M spray before. It works great. I didn't know there were two kinds though. I may have used the 77 instead of the 90 (I don't recall). Whatever I used worked like a champ.
Old Apr 6, 2013 | 07:19 PM
Lady72nRob71's Avatar
and heat resistance... 8090 is made for vinyl tops and headliners, so it will be the best to use on the hood pad
Old Apr 11, 2013 | 07:17 PM
navvet's Avatar
I like idea of a spray...just curious is the glue needed, can I get away with just the metal clips ?? I am thinking of having large polished clips made for me. I just picked up a polished metal cover for my ride-on mower air filter holder. I asked the manager if he could make mirror finished metal clamps for the hood liner and he is going to make them for me. They are about the size of hockey pucks so they should hold the liner on nice.
Old Apr 11, 2013 | 07:36 PM
I did not use glue on mine - just the round plastic retainers from the HELP section at the parts store.
Old Apr 11, 2013 | 09:11 PM
Mine does not have or need glue either
Old Apr 12, 2013 | 12:49 PM
Mine has no clips or attachments, gotta be glued...Tedd
Old Sep 18, 2013 | 05:21 AM
ddd777's Avatar
Question Cement for Hood Insulator
For 1972 the Body Assembly Manual states:
"Apply 9985062 Cement in area shown to hood surface and insulator....."
(see attachment)
How does one decode the part number? Not that I actually expect to be able to find that glue, but more for bolts and screws.....
jvock6
Body work
Apr 8, 2012 06:52 AM
auto_editor
Mar 23, 2011 05:56 PM
jensenracing77
Apr 5, 2010 01:48 PM
Ranzan
Mar 27, 2010 04:20 PM
ztim
Jan 18, 2008 06:47 AM
