'63 slim jim 10 speedo connection
swapped out my slim jim with a replacement - my speedo cable runs to the front wheel. This tranny is set up for a speed cable to the housing. I need a way to plug the hole for the speedometer cable in the transmission housing. Any ideas? THe hole mics at .984 inches. THanks
I used to have a 64 Olds 98 with the same setup but it was such a long time ago I can't recall the specifics. Is it a speedometer cable similar to this one?
https://www.amazon.com/ATP-Automotiv...edometer+cable
If so, you should be able to get a threaded cap at your local hardware store or online. Just figure out the size and thread pitch of the connector and your golden. BTW, pics would help.
