pinion seal change 52 olds
Old Sep 4, 2011 | 02:00 PM
Peewee's Avatar
Unhappy pinion seal change 52 olds
Does this use a crush sleeve or can it just be replaced?
Old Sep 6, 2011 | 12:05 PM
mpolds's Avatar
1948 - 1952 Olds Pinion Seal
I sell them all the time -- and unless you are doing more -- i.e. the whole rear end, axle bearings & seals, differential and pinion bearings & races, etc. -- the pinion seal can be replaced by itself..... the two tiered rear axle seals are getting low on supply, high on demand (they fit '39 - '54 Olds & Pontiac) and always leak also... the repro is pathetic, to be nice...
Best to call me -- Craig -- 516 - 485 - 1935......
Old Sep 6, 2011 | 05:54 PM
Run to Rund's Avatar
Even if it uses a crush sleeve, it can be replaced.
Clean the nut, pinion stem, companion flange recess.
Put a paint stripe across one side of the stem, the nut, onto the flange.
Using the end of vernier calipers, measure the distance from the end of the stem to the beginning of the nut. Use a tool like a piece of 2x2 angle with holes to put two bolts into the companion flange.
Remove nut, flange, seal.
Install new seal, RTV on outside of seal, moly cam Tighten the nut just a hair beyond where it was, using the paint stripe as a guide, and the verniers to be sure you aren't a whole thread off in tightness.
Old Sep 25, 2011 | 10:51 AM
Peewee's Avatar
I called amd left a message but no response,
nonhog
Drivetrain/Differentials
Jul 7, 2011 05:47 PM
oldzy
Dec 22, 2010 07:14 AM
1973olds98
Aug 17, 2010 11:48 AM
drewt
Dec 1, 2009 07:28 AM
jensenracing77
Apr 16, 2009 04:59 AM
