Axles tough to spin
Old April 21st, 2018, 07:51 PM
NotDads442's Avatar
Axles tough to spin
So I’m ******* deep in my chassis restore and I go to put my axle shafts back in my freshly painted housing today and I cannot get the axles to seat far enough to get the wheels bearings in the axle tubes. When I used the bolts to tighten it down it was very hard to turn the flanges or the pinion yoke. I took it off and rechecked it a few times. It’s as though the bearing retainer is being held up by my new axle seals. I put my finger through the seal hole where the axle goes in and the seal is complete seated against the axle tube taper. Not sure what is going on here
NotDads442 is offline
Old April 22nd, 2018, 06:19 AM
monzaz's Avatar
do you have the seal in the correct way? if YOU installed it backwards it will not fit. Send a picture in the hole. Jim
to help you... THE oil spring that is on the inner lip of the seal should always go in where the fluid is ...So if you can see the little spring on the lip of the oil seal from the out side looking in to the tube it is in backwards.
monzaz is offline
Old April 22nd, 2018, 07:42 AM
NotDads442's Avatar
Hmmm. I’ll have to go look. I literally used the seal puller to pull the old seals out, cleaned out the end of the tube and drove in the new seal. I even rechecked the indentation of the old seal before I installed it. I have the flat or painted portion of the seal towards the backing plate.
Old April 22nd, 2018, 06:49 PM
monzaz's Avatar
seal install
Which way? The top seal should be seen from the outside of the flange if your can see the bottom picture orange seal from the flange axle hole it is Wrong.
monzaz is offline
Old August 26th, 2018, 06:03 AM
dennis_30281's Avatar
Sounds familiar, I had the same problem after powder coating everything. Check for to much paint in the hole of the backing plate where the bearing goes through in to the housing. Very tight clearance there.
Dennis...1962 Starfire convertible
dennis_30281 is offline
john mann
August 28th, 2019 02:24 PM
oldsmobilty
Drivetrain/Differentials
June 25th, 2017 06:28 AM
lucille53
June 11th, 2014 10:37 AM
jordan845
May 15th, 2014 06:21 PM
Peewee
September 25th, 2011 10:51 AM
Quick Reply: Axles tough to spin
