Axles tough to spin
Axles tough to spin
So I’m ******* deep in my chassis restore and I go to put my axle shafts back in my freshly painted housing today and I cannot get the axles to seat far enough to get the wheels bearings in the axle tubes. When I used the bolts to tighten it down it was very hard to turn the flanges or the pinion yoke. I took it off and rechecked it a few times. It’s as though the bearing retainer is being held up by my new axle seals. I put my finger through the seal hole where the axle goes in and the seal is complete seated against the axle tube taper. Not sure what is going on here
do you have the seal in the correct way? if YOU installed it backwards it will not fit. Send a picture in the hole. Jim
to help you... THE oil spring that is on the inner lip of the seal should always go in where the fluid is ...So if you can see the little spring on the lip of the oil seal from the out side looking in to the tube it is in backwards.
Sounds familiar, I had the same problem after powder coating everything. Check for to much paint in the hole of the backing plate where the bearing goes through in to the housing. Very tight clearance there.
Dennis...1962 Starfire convertible
john mann
Aug 28, 2019 02:24 PM
