^^In very of a rear axle!!^^
Old Jul 16, 2013 | 03:31 PM
Jesse van der Heijden's Avatar
Dear forum friends,
Im searching for a complete rear axle for my 1968 oldsmobile Vista cruiser.
Its a hard Search but otherwise my special car is "dead".
Maybe an adres to build one.
Just an axle woud be better.
With kind Regards Jesse.
You can mail me at: jesse_van_der_heijden@hotmail.com
Old Jul 16, 2013 | 05:21 PM
Lady72nRob71's Avatar
Welcome aboard!
Around what area do you live? There are Vista parts out there!
What happened to your axle? Maybe you just need parts which may interchange with other years or models...
The more info you can give, the more we can help!
Old Jul 17, 2013 | 12:55 AM
Dear Lady72nRob71
Tanks for The reply!
I live in Rotterdam, Holland.
Im not shure what happend and The car is at the garage right now.
The man said The complete axle need to be replaced it has been fixed a few Weeks ago at another garage but with no luck.
I Will ask for more info...
We will keep in touch.
With kind Regards,
Jesse
Old Jul 17, 2013 | 01:30 AM
Seff's Avatar
You should be able to find an axle in your local area, Olds are not THAT rare.
If all else fails, I have a '72 rear end with a ratio of 2.73, non-positraction, that you can pick up for little money. But it's a long ride, especially with a trailer. But I'm not sure that rear end is correct for your '68 - I'm not even sure it fits, if your '68 has leaf springs.
Old Jul 17, 2013 | 05:04 AM
507OLDS's Avatar
If I remember correctly,the 68 Vista rears had a different axle bearing,and that bearing is not available,unless you can find an NOS one somewhere.If the bearing failed,it probably chewed up the shaft,thus not being able to reuse the shaft.
Let us know exactly what is wrong with it.
Old Jul 18, 2013 | 02:55 AM
Yellowstatue's Avatar
Also the shock attachment bracket is different than a Cutlass or 442...
Old Jul 18, 2013 | 04:39 AM
507OLDS's Avatar
Yes,the Vista rears have slightly different shock mount,but the rears can still be swapped. Been there done that.
Old Jul 22, 2013 | 09:04 AM
Kolby66's Avatar
8z7wg-3831318034@sale.craigslist.org
Here is a 68 vista complete rear in Tucson Az for 50.00
Old Jul 23, 2013 | 06:23 AM
monzaz's Avatar
rear
Wow talk about 1/2 way around the world from Holland...lol.
Really would like to know what is so bad that they say you need a COMPLETELY different rear... Why was the car taken to the shop in the first place? restoration accident ?? etc.?
Here is a list of rears you can make work under the vista cruiser. Most will require a drive shaft being longer by 1" ish. BUT this may be a easier way out then to try and find the EXZACT vista cruiser rear -
1968-1972 Chevelle El camino Skylark Cutlass, GtO tempest 1969-1972 Grand Prix, 1970-1972 Monte Carlo all 10 and 12 bolt versions will fit.
JUST remember some will have different u-joints (easy swap with a precision 372 or Neapco 3-3130 joint also called the BOP to chevy u-joint)
So hope this helps. Jim
J D
HitTheHole
Drivetrain/Differentials
Feb 4, 2021 10:46 AM
droldsmorland
May 3, 2015 07:43 PM
Eddie Hansen
Paint
15
Jun 12, 2012 06:13 AM
cutlasssupreme71
Feb 22, 2011 11:40 AM
9drsixwheelolds
Nov 1, 2010 09:15 AM
