Posi problem, anyone know how to fix posi rear ends
Old September 5th, 2009, 07:55 PM
Not old but Olds
69OldsCutlassS's Avatar
Location: Idaho Native, Boise resident, Emmett Hometown
My limited slip is slipping, when I put the car on the rack the tires will spin opposite directions but if I keep spinning them they eventually both lock up and go the same direction. Anyone know whats wrong and what I could do to fix this. If so were should I get parts. This car is a 1969 Cutlass
69OldsCutlassS is offline
Old September 6th, 2009, 08:22 AM
Sounds like your clutch plates are worn. Since these plates must slip on turns, they do wear out. If you have the plate-style unit, they can be replaced. If you have the cone-style unit they cannot and the whole differential housing must be replaced.
joe_padavano is online now
Old September 6th, 2009, 08:29 AM
Not old but Olds
Is there any way to tell what style I have without taking it apart? Thanks for the info.
Old September 6th, 2009, 10:11 AM
svnt442's Avatar
If it's the original rear (12 bolt cover type O) then it has clutches and can be rebuilt.
svnt442 is offline
Old September 6th, 2009, 10:42 AM
Trying to remember member
wmachine's Avatar
*But* a cone posi can be tweeked to significantly extend the life of a street-used unit.
http://oldsmobilewiki.com/index.php/...:Differentials
Which should seriously be considered if one has a 4-pinion 8.2 10-bolt unit ('66-'67).
wmachine is offline
Old September 9th, 2009, 12:22 PM
Not old but Olds
Thanks for the info, I am having hope on getting even tire wear again, anyone know were to get parts for a 69 olds posi rearend
Old September 9th, 2009, 01:05 PM
wmachine's Avatar
Jim at JD Race http://jdrace.com can help you. He is "monzaz" here on the forum.
wmachine is offline
auto_editor
July 9th, 2015 07:34 AM
ominayak83
April 18th, 2013 10:55 AM
Allan R
Paint
November 25th, 2011 03:11 AM
redvettemike
August 15th, 2009 07:04 PM
z11375ss
July 30th, 2008 10:19 AM
Quick Reply: Posi problem, anyone know how to fix posi rear ends
