Posi problem, anyone know how to fix posi rear ends
Old Sep 5, 2009 | 07:55 PM
69OldsCutlassS's Avatar
Not old but Olds
From: Idaho Native, Boise resident, Emmett Hometown
My limited slip is slipping, when I put the car on the rack the tires will spin opposite directions but if I keep spinning them they eventually both lock up and go the same direction. Anyone know whats wrong and what I could do to fix this. If so were should I get parts. This car is a 1969 Cutlass
Old Sep 6, 2009 | 08:22 AM
Sounds like your clutch plates are worn. Since these plates must slip on turns, they do wear out. If you have the plate-style unit, they can be replaced. If you have the cone-style unit they cannot and the whole differential housing must be replaced.
Old Sep 6, 2009 | 08:29 AM
Not old but Olds
Is there any way to tell what style I have without taking it apart? Thanks for the info.
Old Sep 6, 2009 | 10:11 AM
svnt442's Avatar
If it's the original rear (12 bolt cover type O) then it has clutches and can be rebuilt.
Old Sep 6, 2009 | 10:42 AM
wmachine's Avatar
Trying to remember member
*But* a cone posi can be tweeked to significantly extend the life of a street-used unit.
http://oldsmobilewiki.com/index.php/...:Differentials
Which should seriously be considered if one has a 4-pinion 8.2 10-bolt unit ('66-'67).
Old Sep 9, 2009 | 12:22 PM
Not old but Olds
Thanks for the info, I am having hope on getting even tire wear again, anyone know were to get parts for a 69 olds posi rearend
Old Sep 9, 2009 | 01:05 PM
wmachine's Avatar
Jim at JD Race http://jdrace.com can help you. He is "monzaz" here on the forum.
auto_editor
Jul 9, 2015 07:34 AM
Allan R
Paint
Nov 25, 2011 03:11 AM
redvettemike
Aug 15, 2009 07:04 PM
z11375ss
Jul 30, 2008 10:19 AM
