gear ratio help
Old May 4, 2010 | 01:17 AM
wizzy01's Avatar
gear ratio help
what's up yall, i just got a rear end, and i wanted to check my gear ratio. The code ive found is 2 cf p297n, and is this rear end a 7.5 or 8.5? thanks in advance
Old May 4, 2010 | 05:07 AM
What kind of car is it?
Old May 4, 2010 | 07:18 PM
wizzy01's Avatar
sorry bro, for the late responds its a 1977 oldsmobile delta 88, 403ci
the code was on the passenger side (2 cf p 297 n)
i know the N stands for night, and 297 is the day of the year, and P is for pontiac, but i dont know what the 2 or CF stands for.
Old May 4, 2010 | 08:18 PM
From what info that I have it appears to be a 3.08 rear end. The problem is my info is for the Cutlass/442 models (b-bodies) so I am not sure if the full size cars used the same codes for the gears.
Old May 4, 2010 | 09:03 PM
wizzy01's Avatar
yea thats what my cutlass book says too hope it apply with full size years too, is that 7.5 0r 8.5?
Old May 5, 2010 | 03:18 AM
wizzy01's Avatar
anybody else got some input on the CF code on my rear axle?
Old May 5, 2010 | 01:20 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I need a picture of the rear to tell if it's a 7.5 or 8.5
Old May 5, 2010 | 02:05 PM
wizzy01's Avatar
ok what gear ratio you guys think it is?
Old May 6, 2010 | 10:56 AM
Probably a 2.41:1 if it's from a 77 Delta 88.
My 77 Grand prix rear came with 2.41 posi. My 77 Delta pacecar rear came with 2.41 posi, and all my 80's deltas came with 2.41 open.
Old May 7, 2010 | 02:19 AM
wizzy01's Avatar
i got it from a wreaking yard already pulled, so dont know what car they pulled it from. i thought these codes on the rear axle i gave up would tell me, more about the differential..thanks
Old May 7, 2010 | 06:15 AM
Codes are only worth a crap if you have the book to decipher them.
It's easiest to unbolt the cover and look.
Only 1/2 hour to scrape & replace the gasket.
Old May 7, 2010 | 10:10 AM
Indy_68_S's Avatar
Is there a reason you can't just turn the hub once & count the pinion turns ?
Old May 7, 2010 | 10:17 AM
Because a 3.23 gear would be 3 1/4 turns, 3.42 about 3 1/2, 3.55 about the same. too hard to tell. The difference between 32 1/4 rotations and 34 1//2 would be much more obvious.
Old May 7, 2010 | 10:19 AM
Eddie Hansen's Avatar
X2
That is what i was thinking....
Old May 7, 2010 | 09:36 PM
wizzy01's Avatar
thats what i had the differential shop do, i was just checking out the other threads, before i made this thread and most people was just using the code off the rear end, but no problem, rearends is not my thing, so ill leave it alone..thank guys for checking up with me
Old May 7, 2010 | 09:37 PM
wizzy01's Avatar
will that still work if gears is grinding?
Old May 7, 2010 | 09:39 PM
wizzy01's Avatar
thats well explained, will remember this thanks
442 Guatemala
Jan 15, 2010 10:43 AM
squirell
Jul 7, 2009 09:01 AM
Maverick
Drivetrain/Differentials
Feb 23, 2008 02:27 AM
jeffs 89 cutlass salon
Aug 21, 2007 07:57 PM
442 Guatemala
Jun 11, 2007 10:19 AM
