Type O R&P ID help
Old May 7, 2010 | 05:29 PM
DSM's Avatar
DSM
Type O R&P ID help
I have a 2.78 R&P that was given to me a few years ago. Neither me or the guy I got it from recall what year Cutlass it came out of. I'd like to install it in a 70 Cutlass that has a 2.56 open in it now (reusing the original carrier).
The pinion is stamped:
14A39 GM CD 394701 93
The ring gear has 7/16 RH threads and is stamped:
14A39 GM ZD 92
Obviously the 14A39 is the tooth count...do the rest of the numbers/codes mean anything? My assumption is that these gears should fit the original carrier with no issues, but I recall reading that in '70 the ring gear bolts changed to LH thread..is that right? I didn't get the bolts with the 2.78, so if i can't reuse the bolts from the 2.56 I just want to know up front so I can have all the parts on hand before I start taking things apart.
Old May 7, 2010 | 08:18 PM
2blu442's Avatar
Hi Don
For the work/expense of changing gears I don't think the 2.56 to 2.78 will feel like a significant difference from behind the wheel. If you want a little more zip I'd be looking more at say a 3.23 or even 3.42 if the drop in gas milage isn't real important to you. Just a thought, John
Old May 8, 2010 | 02:09 PM
507OLDS's Avatar
Yes,the 70 O-axle changed to LH threads for the ring gear bolts.67-69 had RH threads.I have some correct RH thread bolts for your 2:78's,if you end up needing them. $5.00 would be plenty.
L77F85
Drivetrain/Differentials
16
Nov 29, 2013 06:19 AM
Indy_68_S
Mar 5, 2012 06:04 AM
bigD
Oct 8, 2011 06:47 AM
Rdrokit
Jul 5, 2009 05:11 PM
