68 442 rear gear ratios
Old September 25th, 2018, 08:29 PM
Billyaxe's Avatar
How can you tell what the gearing ratio is in the carrier? I had what I was told was a 4.62 and replaced it with a 3.42. I have the original part but can’t find any info to confirm it’s 4.62. The pinion has two sets of imprints on it
9442 GM DA
the rings say Timken LM603012 778 08 USA HS.
Anyone know what this is?
Billyaxe is offline
Old September 25th, 2018, 09:00 PM
A 4.66:1 ratio gear set was available as a dealer-installed option on the 1968 W-30 or 442 with manual trans only. These gears required starting with a 4-series carrier, so the car would have come from the factory with either 3.42 or 3.91 gears to start with and the dealer would have changed those out for the 4.66 gears. There was no "4.62" ratio offered.
joe_padavano is offline
Old September 25th, 2018, 09:09 PM
I'll add that the 4.66 gear set for a Type O axle would have a 9-tooth pinion gear and a 42-tooth ring gear. The 3.42 gear set used a 12 tooth pinion and a 41 tooth ring gear.
Old September 25th, 2018, 10:33 PM
Both the pinion gear and the ring gear should have some numbers/letters stamped into them. They should have a GM part number and also the number of pinion teeth and the number of ring gear teeth.
Here's a pic from the web showing the stamping on a 4.10 ring gear. Note the "10 41" is the tooth count (41 divided by 10 = 4.10).
Fun71 is offline
Old September 26th, 2018, 10:56 AM
Billyaxe's Avatar
Mine reads 9A42 GM PG 324
Anyone have any idea what this is? —Billy
Billyaxe is offline
Old September 26th, 2018, 11:02 AM
svnt442's Avatar
That would be a 4.66 gearset.
svnt442 is offline
Old September 26th, 2018, 01:00 PM
9A42 is the number of teeth on the pinion gear (9) and the ring gear (42).
Fun71 is offline
Old September 26th, 2018, 03:07 PM
Billyaxe's Avatar
Thanks guys. Great info. I’m selling that 4.66 gearset off but wanted proof of what it was.
—Billy
Billyaxe is offline
Old April 30th, 2021, 02:35 PM
Mikerlew's Avatar
4.10 Gears, in process of setting up
Hello everyone! So I set my gears up, and it’s just a 4.10 swap after my pinion tore itself apart, I tried to do 0.034” pinion shim, but I needed to add more. I upped it to 0.051” and again to 0.063. (The stock shim was thicker than normal for some reason.)
in regards to the Carrier Shims, I have the shims (stock) and the backlash is at 0.008” so I am satisfied. I just wanted to see if I could get a second opinion about the gear pattern.
From what I am seeing, it appears to be a Toe-Toe pattern, or a mild Heel-Toe. So it’s suggesting that I need to likely add backlash if I am not mistaken?
Drive Side, the marks are closer to the toe, but also centered.
Coast side of gears, again pretty evident of a toe marking
Mikerlew is offline
71OldscutlassS
Drivetrain/Differentials
January 25th, 2020 07:43 AM
67Rocket
June 5th, 2017 07:15 AM
cheven
July 17th, 2014 10:18 PM
1951Super
April 12th, 2012 05:33 AM
Jharken
February 14th, 2012 03:06 PM
Quick Reply: 68 442 rear gear ratios
