1970 cutlass no power after motor swap
Old Aug 20, 2022 | 06:02 PM
Billy’s33s's Avatar
Hey guys.
so I recently got done doing a motor swap on my 1970 olds cutlass and I went today to hook power up to the car to bump it over and I got nothing, no lights no horn nothing inside Or out side the cab. Did I miss a wire or something? I got the purple and the main power wire hooked to the starter and I cant get nothing to come on the battery has 12 volts so I’m really stumped on what’s going on
Old Aug 20, 2022 | 06:20 PM
Make sure you have power at the horn relay bus connection.
Old Aug 20, 2022 | 06:23 PM
Sugar Bear's Avatar
Ground cable hooked up at head/block?
Old Aug 20, 2022 | 06:39 PM
x2
Old Aug 20, 2022 | 07:45 PM
rocketraider's Avatar
Oldsdruid
Two questions:
1) did you put another Oldsmobile engine in it? If not, tell us what's in it so we can do proper diagnosis.
2) do you have the 1970 Olds Chassis Service Manual that has the wiring diagrams in it? If not you need one.
Old Aug 21, 2022 | 10:31 AM
70W-32's Avatar
Power to horn relay
Ground to clean surface on block
Ground from rear of passenger head to fire wall
Old Aug 21, 2022 | 10:42 AM
gs72's Avatar
72Cutlass S
I always put a star washer between the ground cable and block. Ford does this from the factory.
Old Aug 21, 2022 | 10:01 PM
Pretty sure every automaker does this.
Old Dec 19, 2022 | 05:03 PM
PaulWinn's Avatar
Even a dead battery will register 12V
Old Dec 22, 2022 | 06:17 AM
jmcghee's Avatar
HUH??? How does that work?
Old Dec 22, 2022 | 07:02 AM
PaulWinn's Avatar
Try it.
As batteries discharge they dont lose V they lose the ability to push the volts (Amps).
Old Dec 22, 2022 | 07:21 AM
Try it.
They lose both voltage and amperage. A completely discharged battery is 10.5v.
Old Dec 22, 2022 | 07:51 AM
Originally Posted by Billy’s33s
Hey guys.
There are about a bazillion ways to lose power during an engine swap. Get a test light and a wiring diagram and trace the circuit to find out where the power stops.
Old Dec 22, 2022 | 07:55 AM
Since Billy hasn't logged onto this site since August 20th, 2022 @ 09:09 PM I suspect it's highly unlikely Billy is following along.
Old Dec 22, 2022 | 07:57 AM
Old Dec 22, 2022 | 08:02 AM
We "could" steal his thread and discuss Gibb's Free Energy Equation, Electrochemical Potential & Electrode Potential...or, not (my suggestion).
Old Dec 27, 2022 | 06:42 AM
PaulWinn's Avatar
Took my opinion a bit too literally...
I have (what I call) a dead battery - won't turn the engine over, just clicks - and it registers 12 V on my MM. I didn't mean dead dead dead really. A fully charged healthy bat registers well over 12 V.
Some folks might think a 50% discharged bat measures 6V, 75% discharged measures 3V, and so on. That is not the case.
Old Dec 27, 2022 | 06:46 AM
Brians1
Mar 7, 2019 05:57 PM
aardvark
Feb 4, 2016 05:52 PM
becerra66
Mar 20, 2015 12:03 PM
Southern_Hospitality
Oct 12, 2011 06:55 PM
thorpedo91
May 28, 2010 06:08 PM
