92 Oldsmobile cutlass supreme S 2dr coupe door lock switches do not properly engage..
Old April 27th, 2022, 01:59 PM
Bjankins1's Avatar
I have an annoying issue where the automatic door locks will not go up and down, the driver side will go inch by inch the more I hit the unlock button, but will not go back up when hitting lock, the switches when manually moving them feel extremely tight like they are not seated in properly
Bjankins1 is offline
Old April 27th, 2022, 09:31 PM
I remember working in the Buick dealership in those days replacing a little rubber insulator on the door lock actuators. If I remember correctly, the lock would work one way fairly normal, but go really slow the other.
Might be something to look into. It definitely sounds like a actuator issue.
matt69olds is offline
Old April 28th, 2022, 06:21 AM
You can take off the door panel to inspect the door lock actuator. If you R/R anything just make sure you tether the electrical cables properly to the door frame. The UP/DOWN window movement can catch on cables and connectors if they aren't routed correctly.
Olds64 is online now
outrightolds
March 20th, 2022 09:33 PM
Bens71442
April 6th, 2021 07:28 PM
COBRA2000
July 27th, 2020 01:45 PM
leroycjr
March 25th, 2013 01:16 PM
64OldsSarfire
August 6th, 2011 10:48 AM
Quick Reply: 92 Oldsmobile cutlass supreme S 2dr coupe door lock switches do not properly engage..
