need some help replacing the oil pan gasket
Old August 25th, 2009, 08:08 AM
4jo3's Avatar
I own a 69 cutlass with a 350 and i was just wondering if i have to pull the motor to replace the oil pan gasket ... it seems really tight in there and i dont want to start unscrewing bolts and figure i have i have to pull the motor. has anyone one done this while the motor is still in the vehicle.
thanks,
Justin
4jo3 is offline
Old August 25th, 2009, 08:25 AM
thanks,
Justin
It is possible to remove the oil pan with the engine still in the car. It requires raising the engine significantly and lots of four letter words. Personally, I would just pull the engine, since you would only be a few bolt away from that point.
joe_padavano is offline
Old August 25th, 2009, 08:26 AM
car guy
gearheads78's Avatar
At the very least you will need to unbolt the motor and pull it up a little. Not a fun in the car job at all.
gearheads78 is offline
Old August 25th, 2009, 08:32 AM
car guy
Looks like Joe hit enter faster
Old August 26th, 2009, 05:11 AM
Past Administrator
Oldsguy's Avatar
Welcome to CO Justin. Let us know what you end up doing and if you need any help.
Oldsguy is offline
Old August 26th, 2009, 05:53 AM
citcapp's Avatar
Talking Welcome to CO
Wish we had better news and yes its a bi#ch
citcapp is offline
Old August 26th, 2009, 05:57 AM
Are you sure it is the oil pan that is leaking? It could be the rear main seal or the oil drain plug that is leaking. Of course, the oil drain plug is easy to fix, you can get a rubber washer to go in between the plug and the oil pan to prevent leaking. The rear main seal is even more difficult to fix than the oil pan gasket. Just offering up alternative possibilities.
Olds64 is offline
Old April 25th, 2017, 05:56 PM
138milkmen's Avatar
1972 cutlass 350 timing cover removal
Hello again
I was reading my orginal shop manual for my car seein if I want to change the front cover gasket cause it leaks a little after repairing a broken bolt in the front cover. The manual says to remove oil pan then remove front cover? Really? Is that for real or can the timing cover come off without removing the oil pan?
138milkmen is offline
Old April 29th, 2017, 01:33 PM
thirstybob's Avatar
Originally Posted by 138milkmen
Hello again
Lead foot has a nice write up that explains how he loosened several of the front pan bolts and wedged the front of his pan down to make room for and replace the front cover gasket. He even devised a "tool" to "stretch" the front of the pan ever so slightly to make room.
I believe his write up is in the small block section.
thirstybob is offline
fv64olds98
November 6th, 2012 03:20 PM
at3reg98
September 20th, 2012 03:57 PM
trackz man
July 17th, 2011 10:08 PM
dallasite21
June 20th, 2010 05:37 AM
martine
October 17th, 2002 11:52 AM
Quick Reply: need some help replacing the oil pan gasket
