Underhood pics needed...
Old Jul 26, 2009 | 09:04 AM
65az's Avatar
My '65 Cutlass has been missing the radiator overflow bottle.. and I just purchased an original equipment one and need to mount it. If someone could post a picture of the placement of this bottle. My car has Air conditioning.. and was told that it might be in a different spot than a non air car..is this true?
Thanks.
Old Jul 26, 2009 | 06:19 PM
TK-65's Avatar
No such thing as radiator overflow bottle in 65. Rad dumped to ground via rubber hose off cap neck.
Old Jul 26, 2009 | 10:06 PM
65az's Avatar
I was not certain.. but the '65 4door I just purchased from original owner says everything is original on the car.. and nothing has been added or changed.. down to the floor mats. And it has an overflow bottle
Old Jul 27, 2009 | 04:12 AM
rocketraider's Avatar
Oldsdruid
It was added. Factory did not offer it until 1971 and it did not become standard until 1974.
Aftermarket closed cooling systems were/are available thru parts stores. Included a jug, mounting bracket and radiator cap.
Old Jul 27, 2009 | 07:45 AM
65az's Avatar
So if you are keeping your cutty original.. is it worth installing the overflow bottle for environmental reasons over originality?
Old Jul 27, 2009 | 07:58 AM
Nilsson's Avatar
Sure, why would you want to puke that green slim onto the ground.
Old Jul 27, 2009 | 09:36 AM
Since you want to "restore" your car you shouldn't install the overflow tank.
Old Jul 27, 2009 | 11:21 AM
65az's Avatar
I might try to mount it hidden way down below the headlights.. that way I feel more responsible knowing I wont be poisoning any critters, and it will still look original
Old Aug 1, 2009 | 12:41 PM
64 Cutlass's Avatar
not to stir the pot or anything, but if I bought the car in 1965 and had the dealer put on an overflow tank, isn't it original?(just not factory) Lots of accessories were added at the dealer level,right?
Old Aug 2, 2009 | 09:28 PM
65az's Avatar
Interesting thought.. if it was dealer installed.. I would consider that original.. but I guess there is no real way to know for sure if it was actually put on at the time of purchase...
Del70
Jul 21, 2020 11:42 AM
Ddbord
May 6, 2013 06:12 AM
johnspd22
Dec 31, 2009 08:01 AM
oldzy
Sep 14, 2009 05:42 AM
68Tom
Apr 21, 2009 11:53 AM
