Two dumb questions
Old October 25th, 2017, 01:42 PM
asscutl's Avatar
Two dumb questions
Hi 72 cutlass. I currently have air shocks that will no longer hold air. What shocks and or springs are recommended to get to get that high rearend look. Also the cover for the ashtray dosent want to stay in. But all 4 tabs on the cover are there. Did my dash spread or something?
asscutl is offline
Old October 25th, 2017, 04:26 PM
The rear springs depend upon how high you want the rear of the car.
There should be a spring on either side of the ash tray door. They are made of thin metal and may have fallen out when the door was removed..
Fun71 is offline
Old January 21st, 2018, 11:04 AM
Chumley's Avatar
There is never a dumb question. If you don't know something, you learn by asking. Back in the day, I had Gabriel Hi-Jacker air shocks. Just added or released air as needed to get the desired height. Of course this did nothing to enhance road handling, but looking cool was so much more important back then. I think Monroe still makes air-adjustable shocks for these cars.
Chumley is offline
Old January 21st, 2018, 12:30 PM
Proud Viet Nam Veteran
redoldsman's Avatar
As Chumley mentioned, there are no dumb questions. Some of us may come up with a dumb answer on rare occasions but no dumb questions.
redoldsman is offline
Old January 21st, 2018, 12:44 PM
m371961's Avatar
I remember throwing on the air shocks in order to get a decent size tire under the wheel wells.
m371961 is offline
Old January 21st, 2018, 04:42 PM
My old Monte Carlo has air bags still in the rear coils. My granddad put them in so he could drive to Orlando to see my dad, then completely fill the trunk with loose oranges off my dad's trees. I hesitate to guess how many pieces of various citrus one could fit in a 72 A body trunk loose.
Koda is offline
Old January 21st, 2018, 06:20 PM
classicmuscle442's Avatar
Most air shocks have plastic lines and fittings, air them up and check for leaks with soap bubbles.
classicmuscle442 is offline
Old January 22nd, 2018, 08:35 PM
shiftbyear's Avatar
El Camino rear springs are a much higher rate and will definitely raise the back end. You won't need air shocks at all. I don't know what shock is required but it will be quite longer than a standard Cutlass shock. I ordered the 70 El Camino springs. It will put extra stress on your front suspension and may require re-alignment. Good luck
shiftbyear is offline
Old January 23rd, 2018, 10:23 PM
69 Ragtop's Avatar
X2. Just take an old Windex bottle, fill it with about a 50:1 mixture of water and dish soap (Dawn or other), then spray away. You might get lucky and just have a line leak. (Works good for finding air leaks in tires/valve stems too!) -Bob
69 Ragtop is offline
Old January 26th, 2018, 09:45 AM
sschevellecutlass_Bob's Avatar
Thanks for asking the ash tray door question!! I've got a belligerent ashtray door that falls out now and then. Now I know to look for those springs. I have air shocks on Chevelle when I run my 325/50s.... What about a taller tire? The 275/60/15s give my Cutlass a good slight rake. I also like the El Camino spring idea.
sschevellecutlass_Bob is offline
Old February 25th, 2018, 11:29 AM
J69shep's Avatar
I went with Bilsteins and lowering springs from UMI and it rides and handles like a dream. Oh I also put on large front and ear sway bars. Good luck
J69shep is offline
golds56
March 9th, 2012 10:53 PM
cessna195
August 19th, 2010 08:18 AM
shockrebuild
February 22nd, 2010 09:45 AM
Dutch
Ninety-Eight
27
October 25th, 2009 07:26 PM
Oldsguy
October 13th, 2008 11:41 AM
Quick Reply: Two dumb questions
