Wiper motor replacement
Old Apr 11, 2014 | 05:11 AM
Lukewarm's Avatar
On to the next part. After seeing the the multi-meter probe the fan relay, the wiper motor must have decided to throw in the towel. The fuse is good and the white wires in the middle connection have current when the key is on. The other two wires change from open to ground when the switch is moved. The washer pump wires power an aftermarket pump when the switch is pushed.
Am I missing anything or is it replacement time?
If so, can the motor be removed from the mounting hole far enough to remove the nut on the arm or do I have to remove the screen covering the cowl vent?
Any recommendations on a source for the motor?
Old Apr 11, 2014 | 07:05 AM
mrolds69's Avatar
It's doubtful the motor just died. You don't say what year + model it is, but most like ly the screen needs to be removed. You might be able to get the nut off w/o removing it, but you will never get it back on. DON'T CUT THE SCREEN... many peeps cut the screens 'cuz it's easy, replacement screens don't fit right. If you are lazy, you can just release half the screen. Once the motor is out you can bench test it.
Old Apr 11, 2014 | 07:13 AM
Lukewarm's Avatar
Oh yeah, it's a 71 Cutlass Supreme. I have jumpered power and ground directly to the motor, still no dice. I won't be cutting the screen. Do the little push pins holding the weatherstrip and screen down come out nice enough to reuse or does removing them destroy them?
Old Apr 11, 2014 | 08:07 AM
mrolds69's Avatar
71 Cutlass, ok...Google Willcox Corvette wiper motor test. There is some great info + pics there on testing motors. You might be able to do it in the car. The pegs if plastic should come out and be re-useable. If metal, sometimes they break. Only do as many as you have to, to get the nut off. You can use a door panel clip tool, or maybe needlenose opening just enough to get on either side of the clip.
Old Apr 21, 2014 | 04:53 PM
Macadoo's Avatar
I have a '71 CS also and want to refurb my wiper motor but I don't see any tabs or clips holding the rubber over the screen. I've looked and looked but nada. I'm 99% sure it's all original. Could the rubber have been installed with adhesive?
Old Apr 22, 2014 | 07:23 AM
mrolds69's Avatar
There should be clips. I've seen 2 types, metal and plastic. Slide something thin like a putty knife under the rubber until you hit one. Then come from the other direction, you will find the clip pin is about 3/8" wide. You need something to get on either side of it and pry upwards. Some weatherstripping opens at the rear edge and you can get the clips from there. The clips are maybe 6" apart.
Old Apr 22, 2014 | 11:35 AM
Macadoo's Avatar
Originally Posted by mrolds69
There should be clips. I've seen 2 types, metal and plastic. Slide something thin like a putty knife under the rubber until you hit one. Then come from the other direction, you will find the clip is about 3/8" wide. You need something to get on either side of it and pry upwards. Some weatherstripping opens at the rear edge and you can get the clips from there.
Thanks for the tips, I'll give it a try.
Old Jul 21, 2014 | 03:41 PM
Lukewarm's Avatar
These are the plastic clips that were in my weatherstrip. The weatherstrip has been replaced within the last few years.
This is the clip in the weatherstrip.
This is the tool that I used to remove the clips.
Here is the weatherstrip partially removed and the screen lifted for access to the wiper motor nut holding the wiper mechanism to the motor.
Hopefully this helps someone tackle their next project.
47 Convertible
Feb 9, 2019 02:26 PM
oldspackrat
Mar 12, 2015 06:34 PM
razor07
Ninety-Eight
Mar 18, 2014 12:50 PM
jeff618
Nov 22, 2010 06:12 AM
jeff618
Dec 14, 2009 05:49 AM
