Transmission fluid?
Transmission fluid?
Hi I have a cutlass supreme with a 350 and turbo 350 trans (i believe so). The stock owner manual asks for DEXRON ATF for the fluid, but in the 70s it's the DEXRON II time. I saw mobile has DEXRON VI, will that work? Is it going to harm the trans or be beneficial for it since it's newer oil?
You can still find dexron III. The dexron VI is synthetic. It won't harm anything to mix them, its just that the dexron VI costs more.
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
