Transmission fluid?
Old Feb 19, 2017 | 07:36 AM
dddddyang's Avatar
Transmission fluid?
Hi I have a cutlass supreme with a 350 and turbo 350 trans (i believe so). The stock owner manual asks for DEXRON ATF for the fluid, but in the 70s it's the DEXRON II time. I saw mobile has DEXRON VI, will that work? Is it going to harm the trans or be beneficial for it since it's newer oil?
Old Feb 19, 2017 | 08:44 AM
You won't harm anything. I typically use whatever is the cheapest Dexron compatible fluid from the local auto parts store.
Old Feb 19, 2017 | 08:45 AM
Most ATF are backwards compatible.
Old Feb 19, 2017 | 08:47 AM
Anything that says "Dexron" on it should be fine.
Old Feb 19, 2017 | 09:21 AM
svnt442's Avatar
You can still find dexron III. The dexron VI is synthetic. It won't harm anything to mix them, its just that the dexron VI costs more.
Old Feb 19, 2017 | 11:27 AM
442Harv's Avatar
If you read the back of the bottle, it will say, to use in 2006and older, or the newer one says, for 2006,and newer. You want the one for the older. I think the newer one is sympathetic?
Old Feb 19, 2017 | 11:28 AM
dddddyang's Avatar
Yes the DEXRON VI is synthetic
Old Feb 19, 2017 | 10:19 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
I wouldn't recommend mixing synthetic Dex with standard Dex. Stick with standard dyno juice Dextron in this case.
Old Feb 19, 2017 | 10:52 PM
svnt442's Avatar
Sorry Dr....pet peeve.
There is no T in Dexron.
Pookster6
Oct 31, 2011 11:52 AM
gmacolton
Mar 22, 2010 06:41 AM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
asadebo
Alero
May 3, 2009 08:35 PM
American Lead
Nov 16, 2008 04:10 PM
