Testing clock
Old January 21st, 2007, 09:17 AM
Chumley's Avatar
Testing clock
I have a couple of '70-'72 clocks. Do they need to be grounded to the under dash panel to operate? I tested one by just holding it and plugging in the power feed with no result. Then it dawned on me about grounding. The wiring diagram does not show the ground symbol on this connection. I'm not very well grounded(no pun intended) in electrical stuff.....Chumley
Chumley is offline
Old January 21st, 2007, 01:30 PM
Tom Servo's Stunt Double
texasred's Avatar
It grounds through the "ears" on the clock chassis. Hold it so one of the the metal ears is grounded. FYI...most 30+ year old clocks don't work without being worked on.
Here's a good site on clocks....just ignore the fact that it is on Chr%sler products: http://www.imperialclub.com/Repair/A...es/rebuild.htm
C.J.
texasred is offline
lakidd135
August 5th, 2009 09:43 AM
jensenracing77
April 2nd, 2009 03:03 AM
mavrick70004
November 12th, 2008 10:46 PM
Frankenpez
March 31st, 2008 05:43 AM
TheRuss
February 1st, 2008 09:04 PM
Quick Reply: Testing clock
