Testing clock
Old Jan 21, 2007 | 09:17 AM
Chumley's Avatar
Testing clock
I have a couple of '70-'72 clocks. Do they need to be grounded to the under dash panel to operate? I tested one by just holding it and plugging in the power feed with no result. Then it dawned on me about grounding. The wiring diagram does not show the ground symbol on this connection. I'm not very well grounded(no pun intended) in electrical stuff.....Chumley
Old Jan 21, 2007 | 01:30 PM
texasred's Avatar
Tom Servo's Stunt Double
It grounds through the "ears" on the clock chassis. Hold it so one of the the metal ears is grounded. FYI...most 30+ year old clocks don't work without being worked on.
Here's a good site on clocks....just ignore the fact that it is on Chr%sler products: http://www.imperialclub.com/Repair/A...es/rebuild.htm
C.J.
lakidd135
Aug 5, 2009 09:43 AM
jensenracing77
Apr 2, 2009 03:03 AM
mavrick70004
Nov 12, 2008 10:46 PM
Frankenpez
Mar 31, 2008 05:43 AM
TheRuss
Feb 1, 2008 09:04 PM
