Sloppy ignition switch
Old Apr 14, 2009 | 05:58 AM
dingusboy's Avatar
65 Cutlass has an ignition switch that sometimes remains in acc after the key is taken out. Is there a quick fix or is it easier to replace the switch?
Old May 16, 2011 | 11:00 PM
mark_andrews's Avatar
I suggest you replace it with new one's. i had the same problem before and I try to save the old ignition switch so i bring it to a mechanic. The repair is good for a while but after a few days it lose again so I ended up replacing it.
Last edited by mark_andrews; May 18, 2011 at 05:23 PM. Reason: to make post more valuable to the readers.
socalrs
Sep 24, 2012 08:31 PM
Al Graaf
Sep 16, 2012 07:10 PM
MJAKS462
May 6, 2010 01:43 PM
mm89olds
Apr 6, 2006 11:03 AM
oldbutgood
Nov 12, 2002 10:00 PM
