1989 Oldsmobile Delta 88 Ignition Kill Switch Short
Old Apr 5, 2006 | 09:02 AM
mm89olds's Avatar
This car has an ignition kill switch where you need to turn the left turn signal on before starting the car.
Were these installed at the factory?
There is some sort of short now where you can see smoke coming from the center of the dashboard near the clock.
Where do I disconnect the kill switch – which color wires should the harness be?
Old Apr 6, 2006 | 11:03 AM
jdorour's Avatar
I do not think this was a factory install.
I looked in my manual (AllData) and there is nothing that indicates this was a factory install.
Turn signal wires:
From the fuse to the turn Signal Flasher - Dark Blue
From the Flasher to the Switch - Purple
From the switch to the Left Side Front - Light Blue
From the Switch to the Right Side Front - Dark Blue
From the Switch to the Left Rear - Yellow
From the Switch to the Right Rear - Dark Green
Switch Blade Betties
Sep 3, 2013 09:25 AM
theoldsrocket
May 11, 2011 01:14 PM
Rickman48
Mar 23, 2011 01:03 PM
New'n72
Jan 30, 2009 01:42 AM
projectheaven
May 6, 2008 06:45 PM
