how to determine which enhine/transmission i have?
hello, just picked up a 68' cutlass with a 350 & auto trans.
how can i determine which trans. i have? here are a few numbers i got from the bellhousing area : 8610390 Buick
also, the motor has gold valve covers, and the block appears to be gold. what classifies a rocket 350?
any leaks to this info would be great. i tried decoding the vin/body tag but that doesnt seem to help with whats currently in this thing.
thanks.
thanks.
Give this link a try there's a lot of good info here http://www.442.com/oldsfaq/ofe350.htm#E350 350CIDEngineDetail
Here's a link to a thread with some pictures of the engine castings numbers.
https://classicoldsmobile.com/forums...s-engines.html
Then the following post has the vin number location stamped on both the TH350 and TH400. I believe this can only be used for 1968 and newer transmissions. But hopefully this will help you identify which transmission you have.
https://classicoldsmobile.com/forums...-original.html
The term "Rocket" was used to describe the Oldsmobile engines starting in the 1950's (I think!). Any of the 1960's vintage engine could be called Rocket engines. John
jensenracing77
September 10th, 2009 02:10 PM
