how to determine which enhine/transmission i have?
hello, just picked up a 68' cutlass with a 350 & auto trans.
how can i determine which trans. i have? here are a few numbers i got from the bellhousing area : 8610390 Buick
also, the motor has gold valve covers, and the block appears to be gold. what classifies a rocket 350?
any leaks to this info would be great. i tried decoding the vin/body tag but that doesnt seem to help with whats currently in this thing.
thanks.
thanks.
Give this link a try there's a lot of good info here http://www.442.com/oldsfaq/ofe350.htm#E350 350CIDEngineDetail
Here's a link to a thread with some pictures of the engine castings numbers.
https://classicoldsmobile.com/forums...s-engines.html
Then the following post has the vin number location stamped on both the TH350 and TH400. I believe this can only be used for 1968 and newer transmissions. But hopefully this will help you identify which transmission you have.
https://classicoldsmobile.com/forums...-original.html
The term "Rocket" was used to describe the Oldsmobile engines starting in the 1950's (I think!). Any of the 1960's vintage engine could be called Rocket engines. John
