how to determine which enhine/transmission i have?
Old Jan 31, 2011 | 10:59 PM
68cutlassdriver's Avatar
hello, just picked up a 68' cutlass with a 350 & auto trans.
how can i determine which trans. i have? here are a few numbers i got from the bellhousing area : 8610390 Buick
also, the motor has gold valve covers, and the block appears to be gold. what classifies a rocket 350?
any leaks to this info would be great. i tried decoding the vin/body tag but that doesnt seem to help with whats currently in this thing.
thanks.
Old Jan 31, 2011 | 11:32 PM
Fakser's Avatar
Give this link a try there's a lot of good info here http://www.442.com/oldsfaq/ofe350.htm#E350 350CIDEngineDetail
Old Feb 3, 2011 | 08:59 PM
2blu442's Avatar
Here's a link to a thread with some pictures of the engine castings numbers.
https://classicoldsmobile.com/forums...s-engines.html
Then the following post has the vin number location stamped on both the TH350 and TH400. I believe this can only be used for 1968 and newer transmissions. But hopefully this will help you identify which transmission you have.
https://classicoldsmobile.com/forums...-original.html
The term "Rocket" was used to describe the Oldsmobile engines starting in the 1950's (I think!). Any of the 1960's vintage engine could be called Rocket engines. John
Old Feb 7, 2011 | 02:15 PM
droptopron's Avatar
delete
For the transmission the pans are shaped different between a 350 & a 400. Go to Summit or Jegs are see how they are shaped and then look at yours.
Old Feb 7, 2011 | 03:09 PM
TripDeuces's Avatar
Small reference page.
http://www.transmissioncenter.net/PanShapes.htm
Old Feb 7, 2011 | 08:04 PM
well it seems to be that i have the 2 speed auto.
thanks.
Old Feb 8, 2011 | 07:17 AM
thanks.
That was the only automatic offered behind the 350 in the Cutlass in 1968. Only the Vista Cruiser got the TH375, a low-po TH400.
tomjsas
Aug 5, 2010 06:17 AM
JTrujillo
Jul 30, 2010 09:50 AM
Blackjack33
Oct 13, 2009 12:15 PM
jensenracing77
Sep 10, 2009 02:10 PM
<Del81'88Olds>
Jul 29, 2004 04:52 AM
