How do I determine if my numbers match
Old Sep 29, 2009 | 12:49 PM
Blackjack33's Avatar
Registered user
I am looking at a 1969 Cutlass S convertible and have negotiated a general price with the seller; however, I would like to know if the motor and tranny are original to the body. How can I find this out and which numbers are important? Where will they be located? Thanks for the help.
Old Sep 29, 2009 | 01:21 PM
As far as I know, you can't find this out. Oldsmobile didn't start using the VIN derivative stamp until 1971.
Old Sep 29, 2009 | 02:30 PM
svnt442's Avatar
That's not true. The VIN is stamped onto the block on a machined pad just below the #1 spark plug. It will also be stamped on the transmission above the pan rail on the drivers side I think.
It should read something like 39MXXXXXX. The last 6 will match the last 6 of the car.
Old Sep 29, 2009 | 07:47 PM
They started the VIN derivative stamping of the blocks in 1968.
Old Sep 29, 2009 | 09:54 PM
Correct. It was a federal requirement starting in the 1968 model year as an attempt to prevent chop shops from selling stolen car parts.
Old Sep 30, 2009 | 05:52 AM
Oh ok. I was off by 3 years.
Old Oct 9, 2009 | 11:50 AM
vette442's Avatar
If you're still looking for this info, here are the locations for the drivetrain VIN stamps:
Terry
Old Oct 10, 2009 | 12:01 PM
4speedBench's Avatar
Is there any VIN id on axle housing?
Old Oct 10, 2009 | 12:36 PM
svnt442's Avatar
No VIN but there should be numbers stamped into the housing on the passenger side tube.
Old Oct 12, 2009 | 05:43 PM
stlbluesbrother's Avatar
On my car the alternator bracket hinders any chance of seeing the number on the engine block. I wasn't about to unbolt the bracket, so it took a hydraulic lift, some brake cleaner and a mirror to discern the number (and it matched thankgoodness).
Old Oct 12, 2009 | 05:46 PM
Aceshigh's Avatar
Good info here.
I'm going to go check mine now.
Old Oct 13, 2009 | 12:15 PM
mugzilla's Avatar
is Fast Enough ...
It will be permissible to obliterate the numbers ...
j_link
Sep 14, 2013 09:12 PM
72old$
Jul 23, 2011 08:09 PM
jensenracing77
Sep 10, 2009 02:10 PM
Deepsouthauto
Mar 20, 2006 04:14 AM
<Del81'88Olds>
Jul 29, 2004 04:52 AM
