Help removing front coil springs
I'm trying to learn how to do my own work to my 85 cutlass. I am changing my spindles & springs. I already removed the spindles on both sides & the bolts on the bottom of the shocks. What do i need to do now to get the springs out? Am I doing this the right way?
What is the exact state of the car today? You're removed the spindles, but the shocks are still holding the springs in place? If so, you need to temporarily reinstall the spindles. You don't need to torque the nuts, just thread them back on so the spring is retained. Now you need to remove the shocks completely. You need to buy or rent an internal spring compressor (KD brand is one of the better ones) and use it to compress one spring at a time. Once the spring is compressed, you can remove the spindle on that side then remove the spring. Slowly release tension on the spring by unscrewing the compressor and repeat on the other side. Reverse the process to reinstall.
Thanks for the info
Jaap NL
December 18th, 2013 03:40 PM
