Help removing front coil springs
Old Mar 23, 2009 | 11:59 AM
veltboy618's Avatar
I'm trying to learn how to do my own work to my 85 cutlass. I am changing my spindles & springs. I already removed the spindles on both sides & the bolts on the bottom of the shocks. What do i need to do now to get the springs out? Am I doing this the right way?
Old Mar 23, 2009 | 01:27 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Seperate the ball joint from the spindle, and the control arm should swing down. I popped my old springs out with an old stop sign post.
Old Mar 23, 2009 | 02:00 PM
scubastever's Avatar
this is not my car lol
buy (or rent) yourself a good set of coil spring compressors and do it safely. i nearly saw a guy get killed doing it the wrong way.
Old Mar 23, 2009 | 02:54 PM
What is the exact state of the car today? You're removed the spindles, but the shocks are still holding the springs in place? If so, you need to temporarily reinstall the spindles. You don't need to torque the nuts, just thread them back on so the spring is retained. Now you need to remove the shocks completely. You need to buy or rent an internal spring compressor (KD brand is one of the better ones) and use it to compress one spring at a time. Once the spring is compressed, you can remove the spindle on that side then remove the spring. Slowly release tension on the spring by unscrewing the compressor and repeat on the other side. Reverse the process to reinstall.
Old Mar 23, 2009 | 11:54 PM
veltboy618's Avatar
Thanks for the info
Old Mar 24, 2009 | 05:50 AM
wmachine's Avatar
Trying to remember member
Last I knew, Auto Zone (and others) loan them for free. (Refunded deposit)
Old Mar 26, 2009 | 08:27 PM
veltboy618's Avatar
I went to autozone & rented the spring compressor but I didn't need it. When i removed the spindle, that released the tension in the spring. All i needed to do was take the shock out & push the lower arm down. When I did that the spring just fell out. In the rear, I just removed the bolt and pulled the shock off the stud on both sides. After I did that i stood on the wheel studs to tilt the rear end to one side & that spring fell out. I did the same thing to the other side & i was done.
Jaap NL
Dec 18, 2013 02:40 PM
defiant1
Mar 18, 2010 06:43 AM
john suder
Nov 2, 2009 01:21 PM
Flye
Jun 12, 2009 01:21 PM
mcutlass1969
Aug 6, 2006 03:47 AM
