fuel filter
Old May 22, 2007 | 12:00 PM
1987supreme305's Avatar
fuel filter
where is it located on a 1987 cutlass supreme
Old May 22, 2007 | 12:09 PM
crazy'boutOlds's Avatar
Isn't it up in the carb? Mechanical fuel pump, correct? If so, that's were it should be, I think.
Old May 22, 2007 | 07:00 PM
Redog's Avatar
Yeah, the 307 carb'ed cars, it's right in front of the carb.
You need a 1" and a smaller one (7/8" I think) to open the fitler shaft
Old May 27, 2007 | 03:07 PM
87candycutty's Avatar
I just changed mine out yesterday its right in front of the carb you will need two wrenches in order to get the bolts loosened.
Old May 29, 2007 | 07:00 PM
won't gas spray everywhere if i loosen the bolts
Old May 30, 2007 | 04:33 AM
It's not fuel injected, is it? The fuel system runs about 7 psi, I believe. There'll be some fuel leakage from residule left in the line, but that should be it.
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
DanOldsMan
Feb 10, 2014 07:18 AM
PetChemMan
Aug 8, 2006 08:41 AM
