Does this look like a complete Quadrajet 7028251?
Old Oct 11, 2010 | 09:23 AM
yeahbuddy's Avatar
Just won this on ebay and not sure if it looks complete. After I won it I noticed the fuel inlet was crooked and possibly JB Welded on. Also, someone told me the base plate does not look correct for a 68. Is this junk?
Old Oct 11, 2010 | 10:07 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Should serve you well if it isn't broken, and properly set up.
Old Oct 11, 2010 | 10:09 AM
yeahbuddy's Avatar
Does the base plate look correct? Someone told me it does not look correct for a 68.
Old Oct 11, 2010 | 10:38 AM
Rickman48's Avatar
There's no block-offs for the idle adjustment, so it's pre-'80, anyway!
See is you can 'wiggle' the primary shaft when open a small amount - if YES, find someone with a bushing kit that really knows how to install it.
Usually the worst problem on Q-jets, as people think a hard spring will help keep your foot out of it - never worked for me! Just wore out throttle plates!!
Old Oct 11, 2010 | 03:34 PM
yeahbuddy's Avatar
I plan on buying this carb to rebuild and also have the base plate resurfaced and put you bushings on there as well. I just want to verify that it looks like a complete 7028251 and not pieces of different carbs mashed together. Still learning so I cant tell if there is something I am not noticing. It is going on a 68 Cutlass with a 350. My carb on there right now is a 7028250. It has a divorced choke.
Old Oct 11, 2010 | 05:53 PM
BILL DEMMER's Avatar
Just the facts...
it looks ok. there has been some "engineering" done with the fuel inlet, that would be my only concern, from what i can see. a 7028251 will not be calibrated for a 350, it's for a 455. not bad to recalibrate it though.
go for it.
the baseplate looks correct.
bill
Octania
Feb 12, 2012 12:26 PM
bobb
Jul 18, 2011 09:41 PM
Olds Dad
Mar 1, 2011 06:44 PM
yeahbuddy
Oct 23, 2010 01:02 AM
yeahbuddy
Aug 9, 2010 09:58 AM
