72 Oldsmobile Front Alignment issue
I am currently having trouble aligning the front end of my 72 Cutlas. I went from drum to disc brake, replaced springs, basically the entire front end. I am now having camper issues on passenger side. I bought an offset shaft and bushings that helped very little.
Does anyone have any advice on how to get this this front end aligned? I heard that there are longer upper control arms, but haven't had any luck finding them.
Any help to a solution is much appreciated.
Welcome to ClassicOlds.
You said you replaced "basically" the entire front end. What wasn't replaced? To get a good alignment on these old cars you need all new ball joints, bushings, tie rods and idler arm. Even stabilizer bar bushings and links need to be replaced after 30+ years.
jpc647
November 11th, 2014 02:26 PM
