72 Oldsmobile Front Alignment issue
Old Nov 3, 2016 | 04:20 PM
ronrivers55's Avatar
I am currently having trouble aligning the front end of my 72 Cutlas. I went from drum to disc brake, replaced springs, basically the entire front end. I am now having camper issues on passenger side. I bought an offset shaft and bushings that helped very little.
Does anyone have any advice on how to get this this front end aligned? I heard that there are longer upper control arms, but haven't had any luck finding them.
Any help to a solution is much appreciated.
Old Nov 3, 2016 | 04:22 PM
It would help if you explained which settings your having trouble with. Post the settings that your at and the end result you expect.
Old Nov 3, 2016 | 06:03 PM
Olds442redberet's Avatar
I have the same issues on my 1969 Cutlass. The shop said its real close but not perfect.
Old Nov 4, 2016 | 06:19 AM
Yes, posting any sort of fact at all, rather than just vaguely mentioning "camper issues" (I won't even...) would be a small first step.
Welcome to ClassicOlds.
Old Nov 4, 2016 | 08:20 AM
You said you replaced "basically" the entire front end. What wasn't replaced? To get a good alignment on these old cars you need all new ball joints, bushings, tie rods and idler arm. Even stabilizer bar bushings and links need to be replaced after 30+ years.
Old Nov 4, 2016 | 12:30 PM
Was the drum to disc conversion done with factory parts or an aftermarket kit?
#1CutlassSupreme
Body work
Mar 27, 2015 10:00 AM
jpc647
Nov 11, 2014 02:26 PM
Frank3
Jan 31, 2012 11:52 PM
joesw31
Suspension & Handling
Jul 10, 2011 01:33 PM
todd66442
Tech Editor's Desk
Aug 12, 2008 07:43 PM
