1970 Cutlass Column Gear Shifter Questions
Old Feb 22, 2010 | 02:36 PM
cutlass1972s's Avatar
On my 1970 Cutlass when I go to shift into drive (or any gear for that matter) it doesn't move the orange indicator in the gauge. The indicator just stays at park. I was told that it's a cable that's probably unplugged. Is this likely the case?
Thanks for any help
Old Feb 22, 2010 | 03:31 PM
Bluevista's Avatar
Registered
You need a chassis service manual. The shifter indicator is attached to the the bowl on the column that turns with the shifter lever. Probably loose or the screw is gone, came unclipped. Take off the plastic lower column cover cover and you should be able to get to it.
A cable?
Old Feb 22, 2010 | 03:57 PM
Thanks for the helpful information and the illustration Bluevista! You're right I do need a chassis manual. Off to ebay to order one.
we jeep inn's Avatar
I had the same problem on my car. This is what I found. I was able a buy complete setup from CO member. I could have glued it, but the spring that keeps the needle from vibrating was missing on mine.
Old Feb 22, 2010 | 04:06 PM
Thanks for the great pic Robert. Hopefully this thread will help out others with the same problem in the future.
oldspackrat
Mar 12, 2015 06:34 PM
olds66
Apr 15, 2012 02:09 PM
69CutlassAlex
Feb 9, 2012 05:26 AM
Redtide
Dec 17, 2011 12:27 PM
