77 Cutlass 455 swap
Old Jan 19, 2007 | 10:45 PM
curvewrecker's Avatar
77 Cutlass 455 swap
I have a 1977 Cutlass supreme with a 403 and a TH350. After deciding to rebuild the 403, I came upon a newly rebuilt 455 at a price I couldn't refuse.
Its a 72-76 "Fa" block, has E heads, a 1975 iron intake (412753) .040 over pistons, a 204/214 280/290 cam, and probably 8.6:1 compression.
I have no exhaust manifolds, flywheel, water or fuel pump, or carb.
Can I swap these parts form the 403? It has a new edelbrock 600 carb on it, would this be too small, or would it do until I can afford a bigger one?
I'm looking at Blackjack 85029 headers, has anyone used these and do they fit well?
I just bought the car and engine this month, and am new to the Olds V8s.
Old Jan 20, 2007 | 06:53 AM
texasred's Avatar
Tom Servo's Stunt Double
Curve,
Small block exhaust manifolds will physically fit, but they'll be too small to flow well. I think you'll find the Hooker Comp (not Super Comp) headers fit well.
Small block and large block intakes will not swap. You hould be fine on the fuel pump. Flywheel, too.
600cfm is too small...plus I don't think you can beat a QJet. I've run Ebrocks squarebores and not been happy with their low/part throttle response after a LOT of tuning.
I'm having a street/strip 455 built right now. I'm having my TH-350 freshened and slightly beefed to run behind it. It's got better gears than a TH-400, leaches a lot less power, and I don't have to change my drivehaft.
JMHO.
C.J.
Old Jan 20, 2007 | 07:23 AM
2blu442's Avatar
Curve, where are you located? Posting the city and state may provide the parts you need from right across town! John
Old Jan 20, 2007 | 09:31 PM
I'm South of Green Bay, Wi.
Old Jan 24, 2007 | 06:26 PM
2blu442's Avatar
Years ago I bought a 1977 Cutlass that had a 455 TH400 transplanted in. It had the 442 dual exhaust manifolds, the W and Z and they fit fine. It also had a Toronado intake which allowed the hood to close without any clearance problems. I've heard that the Toro intakes arn't good for performance, but this car had 1970 W30 heads on it with a 2.41 posi rear end. Not impressive off the line, but once up to 30-40mph it went to 100 really quick! So... if you had good heads and better gears it might be fine for a street car. I really don't know if other intakes would have clearance problems, I just know this was the setup I had. John
Old Feb 25, 2010 | 10:04 PM
svnt442's Avatar
Ummm.....this is a 3 year old thread.
Old Feb 25, 2010 | 10:22 PM
mugzilla's Avatar
is Fast Enough ...
Just bookmark page ...
Or copy and paste ...
https://classicoldsmobile.com/forums...-455-swap.html
Old Feb 25, 2010 | 10:28 PM
Limey's Avatar
ok thanks didnt know how to do that one. I will delete mine now thanks again
Limey
Apr 15, 2013 10:45 AM
'69CutlassVert'
Aug 25, 2011 07:19 AM
Al2011
Aug 18, 2011 12:52 PM
mcutlass1969
Jun 11, 2009 06:27 AM
