1969 455 cutlass engine swap parking brake cable not installing properly
Old Sep 11, 2010 | 02:06 PM
rida142's Avatar
I am not sure what section to post this in. I have tried a search with no luck. I have a 1969 cutlass that had a 350/350 set up. I have swapped it out to a 455/400 set up. In doing so once i moved the crossmember back and bolted everything up. i went to reinstall the parking park componets. something is not right
The parking brake cables seem to be too long now. i have all three hooks in place and when i run the cable from the front of the car to the rear section of parking brake cable there is way to much slack? can someone please tell me if i have to get a different cable or what i am be doing wrong. Thanks in advance. i will try to get a picture of it to post up.
Old Sep 11, 2010 | 02:30 PM
svnt442's Avatar
The cables are different with the TH400.
Old Sep 11, 2010 | 02:59 PM
rida142's Avatar
which cable do i need to replace the center cable the cables that go into tthe drums or the cable that runs from the parking brake. thx.
Old Sep 11, 2010 | 03:16 PM
don71's Avatar
same but different
You'll need the cable that runs from the parking brake towards the rear.
Wagner part #BC105968....about 20 bucks, here is an example:
http://www.oreillyauto.com/site/c/se...***&vi=1217449
Old Sep 11, 2010 | 03:56 PM
rida142's Avatar
is this the center cable that goes from drum to drum?
Old Sep 11, 2010 | 04:11 PM
don71's Avatar
same but different
Yes is the center cable.
Sorry I gave you wrong info, looking at the wrong section in the manual.
Old Sep 11, 2010 | 05:47 PM
Actually, you need to replace BOTH the front and center cables. The front cable (the one that goes to the pedal) is longer due to the relocated crossmember. The center cable is shorter due to the relocated crossmember.
Front cables are available from RockAuto, though interestingly they don't list them for Cutlii, only for Chevelles. Try these part numbers:
Dorman - C92394
Raybestos - BC92394
AC Delco - 18P2287
Wagner - BC72922
Center (intermediate) cables in the correct length go by these part numbers:
Dorman - C92352
Raybestos - BC92352
Wagner - BC105968
Old Sep 12, 2010 | 08:30 AM
rida142's Avatar
thank you guys for all the help. I have a cutlass only store here in town. ill give them a free plug "Supercars Unlimited" I have been getting a bunch of stuff from them. Thx again for all the help.
Old Sep 12, 2010 | 07:18 PM
Shizzy's Avatar
are those numbers good for 68-72 cars?
Old Sep 12, 2010 | 07:37 PM
Yes, but again, only for 2dr cars with the TH400.
Odmark
Aug 7, 2013 07:51 AM
1977 Delta 88 Flint
Dec 25, 2012 04:23 PM
1acesmith
15
May 17, 2011 09:01 AM
54olds
Mar 31, 2008 06:07 PM
jccc
May 24, 2006 10:24 PM
