Age Old Issue
Old Oct 23, 2017 | 10:13 AM
rickbmac's Avatar
Age Old Issue
Was unsure which area of forum was adequate. Thought I would start here.
Put an Edelbrock Performer RPM intake and Holley Carb on my 350 (1972 Cutlass S). Put an aftermarket air cleaner on top. Now stock hood will not close with this height cleaner.
I understand that the stock cleaner sits down on the carb. I assume this is for clearance.
The issue is that I do not want to inhibit the volume of air being supplied to the engine by installing a lower profile cleaner.
What are the typical solutions to this problem (aside from dealing with a restricted flow)?
Old Oct 23, 2017 | 10:15 AM
You need a drop base aftermarket air cleaner.
Here's one:
https://www.summitracing.com/parts/sum-g3001/overview/
The air cleaner will sit lower on the carburetor to give you more hood clearance. If this doesn't give you enough clearance you will have to go to a different style filter.
Old Oct 23, 2017 | 10:40 AM
rickbmac's Avatar
Purrrrrfect. If I get the correct diameter... hopefully I can use my fancy Oldsmobile stamped top rather than Summit stamp.
Old Oct 23, 2017 | 10:55 AM
Yeah, you can get that with or without the Summit logo. I bought one a year or two ago without the logo when I installed a Summit carburetor. Eventually I went back to the stock air cleaner because I liked that design better.
Old Oct 23, 2017 | 11:20 AM
rickbmac's Avatar
Thanks, I went to high school in Inola, Ok. A long ways from home now.
Old Oct 23, 2017 | 06:34 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Also, I suggest adding a K&N lid to it or the lid/main element kit combo. The drop base (depending on its part number) may require a real thin filter element, IMO not enough air coming in(such as the case with the vette). The lid will ensure enough air.
Check out our vette with the lid.
http://www.jegs.com/p/K-N/K-N-X-Stre...47887/10002/-1
Last edited by droldsmorland; Oct 24, 2017 at 09:19 PM. Reason: making it crystal clear
Old Oct 23, 2017 | 06:44 PM
The drop base uses a standard 14x3 filter. People have been using them on their cars for decades. I'm not a fan of the K&N filter lid.
Old Oct 23, 2017 | 09:26 PM
Agreed. I have a generic chrome air cleaner from the 80s with a factory size 14x3 air filter and no issues with air flow or hood clearance with an RPM intake.
Old Oct 24, 2017 | 05:08 AM
Ken, that air cleaner looks awesome!
I always thought about doing something similar but never acted upon it.
Old Oct 24, 2017 | 09:35 AM
Thanks. I had to do something as after so many years on the humid Gulf Coast the chrome was pitted and peeling. I sanded the lid to remove as much of the pitting and peeling as possible, sprayed it with gold engine paint, then added the decal. Later, I painted over the black insert on the hold down nut with gold paint as well so it matched.
Robertoho
Apr 29, 2014 08:15 PM
edzolz
Nov 13, 2013 07:34 PM
navvet
Apr 23, 2011 12:47 PM
jaunty75
Dec 16, 2010 05:32 PM
derek nesdoly
Cars Wanted
Oct 12, 2009 07:34 PM
