Battery tray permantly bolted on
Old Jun 26, 2010 | 10:58 PM
71 Cutlass's Avatar
One of None W-31
Trying to deduce the best way to remove the battery tray which has some rust issues; however, the bolts holding the tray on are so "covered" in rust ALL OVER, no ratchet fitting will work and the angle is too difficult to allow for vice grips or channel locks. The bolts appear as though they have been taken from the corroded Titanic and placed on my battery tray...they look THAT bad. How to remove them?? An Easy Out perhaps, or other method?
Old Jun 27, 2010 | 04:53 AM
sx455raidercelticfan's Avatar
i had the same problem on my 71 cutlass, we had 2 cut the tray out and the bolts ended up breaking they just kept turing and turning, good luck sorry 2 hear it
Old Jun 27, 2010 | 08:06 AM
Not an uncommon problem. Bite the bullet and grind or drill them out. You may be able to save the threaded nuts on the backside, but don't count on it. You'll either need to use a separate nut or weld new nuts onto the core support.
Old Jun 27, 2010 | 08:55 AM
66400's Avatar
Lots of times I take a smaller size (12 mm) metric scoket and tap it on the bolt head with a hammer. It wedges on and allows you to turn the bolt out. Don't forget to spray on lots of liquid wrench on the bolt threads.
Henry
Old Jun 27, 2010 | 08:58 AM
ddx77's Avatar
Not that this is going to help any but, GREAT LOOKING CUTLASS!
Old Jun 27, 2010 | 09:12 AM
Lady72nRob71's Avatar
Try to chisel away the rust ont he sides of the bolt head, then pound the socket onto it. If it is rounded, pound on the smaller sized socket as mentioned already.
Old Jun 27, 2010 | 02:17 PM
rocketraider's Avatar
Oldsdruid
Air grinder and a good zizz wheel to go on it. Cut the bolt head off to where you can lift out the old tray, then juice up the remaining bolt and try a reverse drill bit to bite into it and back it out. Sometimes a regular drill bit will set up enough vibration to break the corrosion bond and will spin the bolt out thru the bottom of the support.
Plenty of never-seize on reinstallation!
Old Jun 28, 2010 | 05:55 AM
A zizz wheel??
Old Jun 28, 2010 | 05:59 AM
Bluevista's Avatar
Registered
two words...fire wrench.
Old Jun 28, 2010 | 06:02 AM
Lots of liquid wrench / PB blaster! Don't use an EZ out. They always break.
Old Jun 28, 2010 | 06:06 AM
stan 65 cutlass's Avatar
wow, i took mine out in the winter when i painted underhood, all the bolts came out and were reused. i did find a bit of rust on the end of the innerfender. sounds like it coulda been worse musta used never seize in 65
Old Jun 28, 2010 | 07:09 AM
Three words: PLASTIC inner fenders...
Old Jun 28, 2010 | 08:55 AM
lshlsh2's Avatar
71 cutlass convertible
Had to cut and drill mine. major headache. replaced with stainless bolts.
Larry
Old Jun 28, 2010 | 07:42 PM
Blk71SX's Avatar
replaced mine about 2 months ago. I tried EVERYTHING!! 39 years living under a battery there was no way those 2 bolts were going to unscrew. enter the 4" grinder. DONE!!
Old Jun 28, 2010 | 07:50 PM
Oldsdruid
Zizz wheel is a colloquialism for a small grinding/cutoff wheel here. One that is suitable for use on a small air die grinder.
I've also heard it used to describe some exceptionally "talented" women, but we won't go there.
Old Jun 29, 2010 | 03:33 AM
Yellowstatue's Avatar
What ever socket you use- use a six point!!!
Old Jun 29, 2010 | 05:15 AM
Or you might consider getting the sockets from Sears with "teeth" that bite into the rusted bolt. I've never used them but they seem like a good idea.
Old Jun 29, 2010 | 05:29 AM
Blk71SX's Avatar
I tried those but there just wasn't enough of the bolt head left to get a bite. sometimes things don't go as well as they show on tv
Old Jun 29, 2010 | 05:35 AM
What, but Billy Mays advertised it! I thought everything you saw on TV was true!
Old Aug 5, 2010 | 07:37 PM
67442nut's Avatar
Ditto.
Heat works when nothig else does plus you'll save the threads on the welded nut.
Old Aug 5, 2010 | 09:41 PM
oldsonharmont's Avatar
Try some Naval Jelly rust remover to get the loose stuff off, then grab what's left of it with vise-grips and try a socket on the nut below the core support. I did this job too, but mine wasn't that far gone.
Old Aug 6, 2010 | 08:19 AM
Originally Posted by 67442nut
Ditto.
And yet, you'll STILL light the plastic inner fenders on fire...
Old Mar 6, 2011 | 07:48 PM
oregontopcat's Avatar
I ground the heads off, removed the battery box, removed the spacers then soaked with penetrating oil. After setting a while I was able to go from underneath with a pair of vise grips, screwed the bolts out the bottom. Might try this.
Old Mar 7, 2011 | 03:35 PM
greenslade's Avatar
if you don't have a "wiz wheel""you can drill down through the bolt head with a bit the same size as the bolt,then just knock the head off,if you have a welder you could clean up the bolt head and weld a nut onto it then try screwing it out
Kyle's 77 Cutlass
Nov 27, 2014 03:58 AM
69442murph
Aug 13, 2014 06:50 AM
tmatador
Oct 9, 2011 04:25 PM
bcracing
Oct 14, 2009 11:04 AM
Kaline
Feb 5, 2008 08:08 PM
