Running New Fuel Lines with Return 1964 Cutlass
Old Mar 2, 2019 | 12:38 PM
VinMichael's Avatar
My Cutlass currently has the stock 5/16” fuel line. I want to run a new 3/8” steel supply and add a steel return line. This way I can run an external electric fuel pump with a regulator for my Holley 870 street avenger.
I want to use a stock fuel tank with a sump welded on to it. The sump will have two holes for fittings.
From what I have read, the body needs to come off the frame to replace the fuel lines as the factory would have.
I would like to avoid doing this. My question is to anyone who has creatively found a way to plumb new lines with the the body on the frame. Can any holes be drilled in the frame to allow access to run new lines?
rpinnt
May 5, 2018 03:47 PM
Sampson
Nov 7, 2016 07:33 AM
VinMichael
Oct 24, 2016 04:10 PM
toro455
Jul 6, 2011 11:37 PM
mcutlass1969
Dec 17, 2010 06:02 AM
