1964 Cutlass Fuel Line Replacement EFI Conversion
Old July 9th, 2016, 06:56 PM
VinMichael's Avatar
Hello All,
I have a 1964 2 door post car that I would like to replace the fuel lines for 3/8", and also include a return line for its EFI conversion. From what I've read, to replace the fuel line properly I need remove the body from the frame so I am planning to take on that project.
My question is whether anyone has recommendation for a company who carries a pre-bent line or if I am better off bending my own lines. Also If I bend my own lines, should I use stainless or mild steel lines? From what I read mild steel may be easier to bend? So I don't know if stainless steel is truly worth the extra work.
VinMichael is offline
Old October 24th, 2016, 11:30 AM
ART T's Avatar
If you don't use a one piece fuel line you can replace it with the body on. Use the existing line for the return.
ART T is offline
Old October 24th, 2016, 04:10 PM
therobski's Avatar
Couple of ideas: on my 64 Pro Touring I used Parker 3/8 Push Lock and on the 67 1/2 steel braided line, both have Carbs-no EFI system but easy to work with if your building from scratch.
therobski is offline
dfire25
June 28th, 2016 01:37 PM
70 ctls
March 17th, 2015 09:18 AM
Del70
November 15th, 2013 02:24 PM
davepnola
December 2nd, 2010 09:00 PM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: 1964 Cutlass Fuel Line Replacement EFI Conversion
