Sway bar support bracket
Old August 5th, 2018, 12:24 PM
kbdecatur's Avatar
The screw hole is stripped out I went up to a larger bolt to hold it up but it didn’t work. Does anyone what will be the best fix for this. I was thinking of getting cutting it out and getting welded back in. Any help would be appreciated.
kbdecatur is offline
Old August 5th, 2018, 01:24 PM
You need a nutsert (also called Riv-Nut). Basically it's a large pop rivet with internal threads. Requires a special installation tool, like a big pop riveter.
joe_padavano is online now
Old August 5th, 2018, 02:34 PM
72 Olds CS
RetroRanger's Avatar
I tapped the hole the next larger size w a fine thread and then after much effort was able to thread a nut onto the bolt inside the frame
RetroRanger is offline
Old August 5th, 2018, 05:24 PM
Chesrown 67 OAI's Avatar
Self-tapping bolts are great in this situation
Chesrown 67 OAI is offline
Old August 5th, 2018, 06:51 PM
kbdecatur's Avatar
Thanks guys!!!
1BOSS83
Suspension & Handling
December 14th, 2017 06:19 AM
TWP442
April 20th, 2013 11:23 PM
RetroRanger
June 13th, 2012 04:48 AM
oldzy
April 11th, 2011 07:35 AM
bccan
September 30th, 2010 06:49 AM
Quick Reply: Sway bar support bracket
