Sway bar support bracket
Old Aug 5, 2018 | 12:24 PM
kbdecatur's Avatar
The screw hole is stripped out I went up to a larger bolt to hold it up but it didn’t work. Does anyone what will be the best fix for this. I was thinking of getting cutting it out and getting welded back in. Any help would be appreciated.
Old Aug 5, 2018 | 01:24 PM
You need a nutsert (also called Riv-Nut). Basically it's a large pop rivet with internal threads. Requires a special installation tool, like a big pop riveter.
Old Aug 5, 2018 | 02:34 PM
RetroRanger's Avatar
72 Olds CS
I tapped the hole the next larger size w a fine thread and then after much effort was able to thread a nut onto the bolt inside the frame
Old Aug 5, 2018 | 05:24 PM
Chesrown 67 OAI's Avatar
Self-tapping bolts are great in this situation
Old Aug 5, 2018 | 06:51 PM
kbdecatur's Avatar
Thanks guys!!!
1BOSS83
Suspension & Handling
Dec 14, 2017 06:19 AM
TWP442
Apr 20, 2013 11:23 PM
RetroRanger
Jun 13, 2012 04:48 AM
oldzy
Apr 11, 2011 07:35 AM
bccan
Sep 30, 2010 06:49 AM
