Upper control arm cross shafts
Old May 18, 2019 | 09:42 AM
scrappie's Avatar
I just blasted and cleaned my upper control arms and cross shafts. The cross shafts are a little more pitted than I thought. I was looking for exact replacements and can't seem to find the exact one? I would need the washers and nuts also to go with. My shafts are for a 1970 442 with the ends threaded with a washer and nut.
I have seen some that have a bolt and washer that is threaded onto the shafts also and I have a pair of those but wanted the exact replacement.
Moog has some but they are offset and not exact and sold as a kit. I already have new bushings to install and dont need the whole kit.
I suppose I could use my old ones but would need new nuts and washers at minimum.
Anybody supply any of these and know what they look like?
Old May 18, 2019 | 12:12 PM
Moog part number for the problem solver shafts with 2 nuts, washers, and bushings is MOOGK5250.
Old May 18, 2019 | 03:16 PM
scrappie's Avatar
Those are the offset shaft kits.
Might have to be the way to go......Thx
Old May 18, 2019 | 03:22 PM
They aren't offset much, and actually lower the amount of shims required if you want extra caster.
Old May 18, 2019 | 03:41 PM
scrappie's Avatar
Thx Eric I may go that route.
Old May 18, 2019 | 09:49 PM
70Post's Avatar
Scrappie - where are yours pitted?? Just on the exposed surfaces?? How about the smooth part of the shaft that the bushings slip over? They can be "bodyworked" on the exposed areas and then painted to look like they're a phosphate finish.
New washers and lock nuts are readily available. (check w/Inline Tube for the washers and lock nuts are easily found at local fastener supply places for low $).
That or find super clean original used pieces....not the easiest thing to find but not impossible either if you can source them from the drier areas of the country.
Old May 19, 2019 | 09:36 AM
scrappie's Avatar
These are mine. What do you guys think?
Old May 19, 2019 | 10:03 AM
70Post's Avatar
They are both "fixable" and the shaft on the top would be relatively easy since the pitting isn't deep. Lower shaft.....that would make me look for a nicer original candidate or two.
I took the liberty of sending a message to a guy I know out west to ask what he had, if anything.....he typically has some real "dry"/nice parts. If he responds then I'll put you in touch with him direct....I'm not trying to "middleman" anything.
Again, washers and nuts you can easily buy new so no need to worry about those.
Old May 19, 2019 | 07:30 PM
scrappie's Avatar
Thx Patton
Old May 19, 2019 | 09:01 PM
70Post's Avatar
PM sent scrappie
jharsh
Suspension & Handling
17
Apr 26, 2019 07:38 AM
borgerding
May 10, 2016 07:05 AM
1969cutlass4d
Feb 26, 2015 08:56 PM
johnnyjaws
Jun 16, 2014 08:48 PM
olds1968
Jun 10, 2009 12:41 PM
