Taillights and turn signal assemblies and seals
1970 Cutlass S
My front turn signal housing on the DS is missing the gasket. Is there a repro source for these? Also, it is missing the correct partially threaded screws. It seems the PO lost/replaced them for some reason.
Correct screw (missing two)
And the rear PS taillights need quite a bit of attention. The lens/light housings mount is corroded away quite a bit and needs to be replaced along with the correct missing screws. And new gaskets, they are quite bad. Is there a source for repro replacements of these things?
The DS lenses/housing/mount is still decent.
Thanks all!
Thanks all!
Thanks! They have all of that stuff. Forgot about them since for the first time, I am starting to buy repro stuff for an A-body.
I also need the taillight lens mount housing for the PS. How have dealings with The Parts Place been? They have this and I was wondering about fit/finish:
https://www.thepartsplaceinc.com/pro...using-ea/83365
